Warranty The Dometic DFSD20111 comes with a 2 year parts & labor warranty. Warranty does require that the unit be taken into an authorized Dometic service center for repair. Service Center Locator Helpful Articles A/C runs when in Furnace Mode ...
*The Bluetooth Thermostat is not standard but can be purchased for use with all Dometic Penguin A/C units in the Oliver camper. With this option if your current A/C has the heat strip it would be lost when switching to the Bluetooth version.
Warranty The Truma VarioHeat comes with a 2-Year Parts & Labor warranty through Truma. Warranty does require that the unit be taken to an authorized Truma service center. To locate an authorized service center contact Truma Service at 855-558-7862 ...
Warranty The Truma Aventa comes with a 2-Year Parts & Labor warranty through Truma. Warranty does require that the unit be taken to an authorized Truma service center. To locate an authorized service center contact Truma Service at 855-558-7862 Ext ...
GENERAL INFORMATION FROST FORMATION Frost Formation On Cooling Coil Frost on a small portion of the coil is not unusual. Under certain conditions, ice may form on the evaporator coil. This is indicated by very cold output at very low air speed and ...
