Regardless if you winterize your camper, just drain the water for storage, or use the system year round; at some point you will want to sanitize the fresh water system. This may sound tedious but with your Oliver Travel Trailer you can simply use the winterization/boondock port at the rear of the camper and let it do most of the work for you.
If you did winterize your camper, you will want to de-winterize prior to sanitizing the system. Please see De-Winterization for details on how to de-winterize.
Sanitization can be done at any time but is most often done after pro-longed storage or pro-longed use.
